Continuing Calcualtion issue
Thread began 5/21/2011 9:48 am by James L | Last modified 5/23/2011 8:26 am by Jason Byrnes | 1277 views | 3 replies |
James L
I couldn't find the original thread for this (I printed it and the header says t=20502) but it had to do with setting the height and width of a shipping box based on Quantity.
the code (copied from the ProResCart_PHP.php file on line 12 is:
$itmObj->boxheight = abs($itmObj->Quantity==1)?[ItemHeight]=8:[ItemHeight]=14;//i
the formula I entered in the eCart Calculations is:
abs([Quantity]==1)?[ItemHeight]=8:[ItemHeight]=14
Yet every time I try to open any of my pages in a browser I get this error:
Parse error: syntax error, unexpected '[' in /Applications/MAMP/htdocs/ProRes-from-scratch/WA_eCart/ProResCart_PHP.php on line 12
What's going on?
what are the names of the columns in your cart?
this calculation is assuming that the item height column is named:
ItemHeight
Pay attention to case as well. The error suggests that the item height column is named something else. the calculation will need to be modified to use the correct name for the item height column.
James L
data names look OK but is Type wrong?
I've a screen cap attached (from phpMyAdmin), indicating that the names are ok, but I'm now wondering about the Type. I'm using Integer, should I use something else? would that make the calculations work differently?
I'm not referring to the columns in your database table, I'm referring to the columns in your eCart object.
