Huge Shipping charge displayed in Cart
Thread began 5/20/2011 8:20 am by James L | Last modified 5/23/2011 7:30 am by Jason Byrnes | 1055 views | 3 replies |
James L
I can't figure out where this weird shipping charge comes from (2 lb product but shows shipping as $40.82! - see attached screen capture). This is on the initial Cart page, before Checkout (i.e. an address has not even been entered yet). I don't even want Shipping and Tax to be calculated at this point, much less displayed. These two things should only be displayed on the Confirm page.
How do I keep shipping out of the process until after Checkout?
what shipping charges are defined in the eCart object on the shipping tab?
can you send a link where i can see the problem?
If only it could be that the shipping is showing from another test item where it got stored in a session. Close the browser completely to destroy the session and test again
James L
Works but is there a better way?
Shutting down the browser and restarting it does work to clear the session info, but that's a pain when I'm modifying things during development. Is there some code I can attach to a button temporarily to clear the cache? Or can I just add some code to the Cart "clear cart" button that will actually clear the cart.
use the Cookies Toolkit Clear Session value server behavior.
create a page called ClearSession.php
add the Clear session value server behavior to it, set the trigger to before page load, and set it to clear all.
Create a link to this page to clear the sessions.
