upload folder error
Thread began 5/20/2011 4:35 am by eyoung296270 | Last modified 5/23/2011 8:27 am by Jason Byrnes | 1823 views | 5 replies |
eyoung296270
upload folder error
I have an html editor with file manager set up on my website. I originally had the folder image as the upload folder but then changed it to be a subdirectory of uploads. So the uploads folder should be reading image/uploads. The uploads are going to the right folder but the file directory path is showing imageuploads and not image/uploads. How do I fix this.
in the webassist/kfm/configuration.php file, what is the
$kfm_userfiles_address
and
$kfm_userfiles_output
setting set to?
eyoung296270
address is ../../image
output is set to = abs2rel ($_SESSION['useOverrideRoot'],dirname(_FILE_));
eyoung296270
correction the out is set to = rel2abs($kfm_userfiles_address,dirname(_FILE_));
eyoung296270
I used a little common sense and realized that the configuration folder needed a / after the images folder. It is all working fine now.
Thanks for your help Jason!
glad to hear it is working.
