Working with Security Assist
Thread began 5/17/2011 6:43 pm by johna1964 | Last modified 5/18/2011 7:29 am by Jason Byrnes | 726 views | 1 replies |
johna1964
More questions:
When you run the Security Assist Wizard and choose email address for logging in (Step 5; Login Field), wouldn't you continue to use the email address also for Step 6; Login Details instead of the user name column?
Also, if not then I need to add a user name column to the database user table, even though there is already the user first and user last name columns. Will this create a problem?
I am using the wa_eccomerce_db.
This question is also relevant to another step in the Updating Send Password process.
Please advise...
Thank you!
Yes, if the email address column is used as the Username column for login, then it should also be used as the username column in other steps of the wizard, and for creating the forgot password page.
