PowerGallery during install - blank page
Thread began 5/17/2011 6:26 am by info290144 | Last modified 5/18/2011 8:57 am by Jason Byrnes | 1190 views | 3 replies |
info290144
In the process of installing PowerGallery, just after the first page where it checks if php is working (which passes with ckeck marks), it turns to a blank page when I click next. I tried installing it using a different folder but this time it just turns to a blank page!
Please help me fix this problem as soon as possible.
Thank you.
on the page that shows blank, add the following code at line 1 to turn on error reporting:
error_reporting
(E_ALL);
info290144
This is the error that comes up:
Fatal error: Call to undefined function mysql_set_charset() in /var/www/vhosts/lakeviewranch.com/httpdocs/lakeviewgallery/Connections/powergallery.php on line 10
I can't find the page powergallery.php
the Connections/powergallery.php file gets created during the install, you will need to download it from the server.
Then add the following code at line 1:
if (function_exists('mysql_set_charset') === false) {
     function
mysql_set_charset($charset$link_identifier null)
         if (
$link_identifier == null) {
             return
mysql_query('SET NAMES "'.$charset.'"');
         } else {
             return
mysql_query('SET NAMES "'.$charset.'"'$link_identifier);
