Site Import Not Working
Thread begun 5/15/2011 6:56 pm by delroyabrown387179 | Last modified 6/09/2015 2:47 pm by Ray Borduin | 7854 views | 13 replies |
delroyabrown387179
I'm on an a PC. Dreamweaver CS5
In the site import wizard I enter the URL in Main we sit e URL. I select my folder for download and hit "next".
I did not change anything on step 2
I check Download template on step 3 and click finish
Then dreamweaver freezes for 3-5 seconds then nothing happens
On my WAImortlog.txt, it says Importing URL and the name of the site, but there is nothing there.
What can I do?
this is the site I ma trying to download.
btsite/
DBS19572
Site Import NOT Importing
I am had great success in the past with this product but today is not good. I even upgraded from version 1,2 now 3 and running W7 x64 with Master Suites CS5.5.
First off a pain to even to get it to launch.
Second now it does not import, however it will run a report, but only not to generate one...
Need to use this product ASAP!!!
I have followed all tech sheets, troubled shoot and still no go!
Guess I missed the part about running Dreamweaver as Administrator and it will work!!!
Hope this Tid bit helps others!!!
"Guess I missed the part about running Dreamweaver as Administrator and it will work!!! "
from this it sounds like you have got this working now?
Andrew Dodd - ADDIGITAL
Hi Jason,
I'm having this issue with v3.04 on the Mac with DW CS 5.5 - do you have any suggestions?
TIA
Andrew
what is the path you are setting the site to import to?
try setting up a new site in dreamweaver and setting the import to save to the new DW site,
Hi Jason,
I've tried to do this several times but when you set the import off, the WebAssist panel just freezes and no import happens, apart from the logfile being created in the destination directory. Dreamweaver itself is still active and doesn't freeze.
Kind Regards
Andrew
you don't answer my question:
can you send a copy of the log file please.
Hi Jason,
I think I've solved it - I removed the http: from the URL at the bottom selector - that seems to have solved it..
Kind Regards
ok, glad to hear it is working.
