Two issues (not working) in latest e-cart
Thread began 5/13/2011 10:48 pm by welcomcat385026 | Last modified 5/17/2011 11:01 am by Jason Byrnes | 1202 views | 3 replies |
welcomcat385026
CHECKOUT WIZARD>File destination for checkout,confirm, failure, success files
Even if you press folder icon and select file destination, it does not work. You have to type the destination manuallu.
CHECKOUT WIZARD does not show the second or third e-cart object.
I cleared %appdata%.
Originally Said By: welcomcat385026
What is your OS? and Version of Dreamweaver?
Can you send a screen shot showing the issue sao I can get a better understanding.
The checkout wizard will use the eCart object of the cart display page that is open when you start it.
Whatever eCart object is used for the cart display page that is open in Dreamweaver when you start the checkout wizard is the cart object that will be used by the checkout wizard.
welcomcat385026
one issue solved, thank you
I was making two shopping pages at the same time and two cart pages were open. So wizard gave priority to the first left in DW(CS4) interface.
The second issue seems to be there and I have to place the file destination manually with / in the end.
I have verified this behavior in my version of Dreamweaver and have logged a bug so it can be corrected in a future update, thank you for bringing this to our attention.
