Uninstall Problem
Thread began 5/13/2011 12:54 pm by bobrast313015 | Last modified 5/13/2011 1:14 pm by Jason Byrnes | 810 views | 1 replies |
bobrast313015
Uninstall Problem
I just had an inexplicable problem with long-installed Webassist extensions causing startup errors in Dreamweaver CS5. So, I uninstalled all WebAssist extensions via Adobe Extension manager. Now, each time I start Dreamweaver, I get a series of errors:
"Unable to find file WA_xxxx.htm in the Configuration/Floaters directory. The floater will not be shown"
Happens for WA_Memento.htm, WA_SiteTools.htm, WA_SiteTools_Process.htm.
Is there an xml or dat file in Dreamweaver's config directory I need to edit fix this? I'd like to reinstall my WebAssist tools but am leery about doing that until know what the issue is.
Thanks,
go to Window -> Workspace Layouts -> Reset '<Your Layout Name>'
