re-installing after new hard drive
I'm using DW 8 as part of my CS2 package - cosa I just can't afford to upgrade and it does what I need it to, but I've just had to replace my hard drive and am having trouble with an error relating to WA
I found and removed the DAT file as per instructions, with a slight variation on the location given my suite is older, and this has made the problem less persistant, but it is still occurring to the point that the programme is unusable.
I've also set WA to never under options - that's not stopped it either :(
The following translators were not added due to error (s). The following javascript error occurred.
Unable to open script file
c:\programme_files\macromedia\Dreamweaver\config\shared\constantcontact\library\WA_configuration.js"(errors)
(copied quickly by hand from screen, so might not be exact text, but the structure is right)
