Limit Quantity
Thread began 5/10/2011 5:24 pm by Martin | Last modified 5/13/2011 7:41 am by Jason Byrnes | 1075 views | 3 replies |
Martin
Limit Quantity
Hi there,
I am working on a Power Store for a customer. I was wondering if I can limit the number of quantity on an item.
The client has a sample item at a great price, but I want to limit it to only 1 per purchaser.
If that is not possible, how about limiting the quantity in the cart to only 1, is there any way to do this or to custom code it?
Thanks,
Martin
you would need to use eCart to modify the store for this.
you would need to create a calculation in the power store eCart object using the ID of the item.
the calculation would be:
abs([ID] == '22')?[Quantity]=1:''
this is an example using item ID 22. If that item is in the cart, it will force the quantity to 1 even if the shopper tries to set it to another value.
Martin
Ahh, I follow what you are saying. Great, I will give it a try.
Thanks,
Martin
you're welcome.
