Save date in seconds since the Unix Epoch 'U'
Is it possible to setup the date-picker to post the 'U' value (Seconds since the Unix Epoch) into my database but show friendly dates, in my case UK format (jS M Y).
you can convert the the date that is posted by the datepicker to a timestamp using the strtotime() function.
in the insert record behavior, when you bind the date column to the date form element, it will generate code similar to:
[php]
<?php echo((isset($_POST["thedate"]))?$_POST["thedate"]:"") ?>[php]
change that to:
[php]
<?php echo((isset($_POST["thedate"]))?strtotime($_POST["thedate"]):"") ?>[php]
in order to store the timestamp.
