Security Question in Registration
Thread began 5/09/2011 4:56 pm by Maplemac | Last modified 5/10/2011 7:53 am by Jason Byrnes | 1279 views | 1 replies |
Maplemac
How do I get rid of the Security Question on the registration form.
I don't need both Captcha and the question.
in the webassist/plugin/registration/full/registration.php file, delete the folloing code blocks:
line 516:
var sprytextfield10 = new Spry.Widget.ValidationTextField("sprytextfield10", "none", {validateOn:["blur"]});
lines 477 - 496:
<p>
                <div class="text"><?php require_once("../../../../WA_ValidationToolkit/WAVT_CaptchaSecurityQuestion.php"); ?></div>
            </p>
            <p>
                <label for="Security_question">Security Question:</label>
              <span id="sprytextfield10">
          <input type="text" class="WAATKTextField" name="Security_question" id="Security_question" value="" size="32" onBlur="if (document.getElementById('RandomQuestionServerValidation')) document.getElementById('RandomQuestionServerValidation').style.display='none'" />
          <span class="textfieldRequiredMsg">A value is required.</span></span>
if (ValidatedField("usersRegistrationfull","usersRegistrationfull"))  {
  if ((
strpos((",".ValidatedField("usersRegistrationfull","usersRegistrationfull").","), "," "8" ",") !== false || "8" == ""))  {
    if (!(
false))  {
          <span class="textfieldServerError" id="RandomQuestionServerValidation">
              Your answer was incorrect.        </span>
          <?php //WAFV_Conditional users_Registration_full.php usersRegistrationfull(8:)
            </p>
line 64:
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_question"]))?strtolower($_POST["Security_question"]):"") . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,8);
