Discount based on item and item quantity
Thread began 5/09/2011 3:08 pm by mora398588 | Last modified 5/10/2011 10:26 am by Jason Byrnes | 1797 views | 5 replies |
mora398588
I am looking to create a coupon code for 25% off a specific item in my cart. In addition, I would like the cart to take into account the quantity of the specific item so that the shopper can get the discount not just on one of the items.
I have already created the coupon code and the ability to enter the code on my site. I having difficulty just getting the code setup.
Please see attachments.
eCart Rule.zip
eCart1_PHP.zip
The trigger section will be set the same way as the Coupon Code Recipe.
For the calculation section of the discount, you will need to know the ID of the item to apply the discount to, for example sake, lets say the ID is 22. The calculation should be set as:
based on Items With a specific column value:
Total of 'TotalPrice' where 'ID' has a value of '22' times '0.25'
mora398588
I followed your directions and modified the trigger to reflect the coupon code recipe, as well as update the calculations per your recommendation.
However, the cart is only applying the discount to only one item (in this case, item 3). It appears that however the "totalprice" is being defined, the cart is only recognizing the total price for one item and not the total price of the item times the total quantity of the item.
For example, if I am shopper and I wanted to purchase 4 of the item 3's using the coupon code, I would want to have the coupon code apply a discount on the total of all 4 of the item 3's.
How do I get the cart to recognize the quantity field or the total number of items (item 3) there are. Do I need to add this event as another trigger? - please see previous pdf attachment outlining my previous setup. I made an attempt to add a trigger to recognize the quantity, but this did not work.
eCart Setup1.zip
you have used total of 'Price' in the calculation.
you need to use total of 'TotalPrice' instead.
from the dropdown list where you select the column, select the TotalPrice column which is calculated as Price * Quantity
mora398588
I noticed my oversight...thank you for your help. Working great!
you're welcome.
