MySQL syntax error
Thread began 5/09/2011 7:31 am by info425534 | Last modified 5/09/2011 5:21 pm by Jason Byrnes | 925 views | 3 replies |
info425534
MySQL syntax error
Hi there,
I've got my site set up and online, and everything works great except for the users_Profile.php page. I can register new users, login and log out etc etc, but whenever I try to go to the user profile page I get the following error:
"You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '@mydomain' at line 1"
I'm not sure what could be causing this. Especially since everything else works fine. Here is the php code from the users_Profile.php page - maybe you can see something i'm missing....
if (!isset($_SESSION)) {
session_start();
<?php require_once('Connections/login.php'); ?>
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
if (!WA_Auth_RulePasses("Administrator")){
WA_Auth_RestrictAccess("AccessDenied.php");
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_update"])) && ($_POST["MM_update"] == "WAATKUpdateForm")) {
$updateSQL = sprintf("UPDATE users SET UserPassword=%s, UserFirstName=%s, UserLastName=%s, UserCity=%s, UserState=%s, UserZip=%s, UserRegistrationDate=%s, UserVerificationCode=%s, UserIP=%s, UserPhone=%s, UserFax=%s, UserCountry=%s, UserAddress=%s, UserAddress2=%s, userLevel=%s WHERE UserEmail=%s",
GetSQLValueString($_POST['UserPassword'], "text"),
GetSQLValueString($_POST['UserFirstName'], "text"),
GetSQLValueString($_POST['UserLastName'], "text"),
GetSQLValueString($_POST['UserCity'], "text"),
GetSQLValueString($_POST['UserState'], "text"),
GetSQLValueString($_POST['UserZip'], "text"),
GetSQLValueString($_POST['UserRegistrationDate'], "date"),
GetSQLValueString($_POST['UserVerificationCode'], "text"),
GetSQLValueString($_POST['UserIP'], "text"),
GetSQLValueString($_POST['UserPhone'], "text"),
GetSQLValueString($_POST['UserFax'], "text"),
GetSQLValueString($_POST['UserCountry'], "text"),
GetSQLValueString($_POST['UserAddress'], "text"),
GetSQLValueString($_POST['UserAddress2'], "text"),
GetSQLValueString($_POST['userLevel'], "int"),
GetSQLValueString($_POST['UserEmail'], "text"));
mysql_select_db($database_login, $login);
$Result1 = mysql_query($updateSQL, $login) or die(mysql_error());
$updateGoTo = "users_Profile.php";
$updateGoTo .= (strpos($updateGoTo, '?')) ? "&" : "?";
$updateGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s", $updateGoTo));
$ParamUserEmail_WAATKusers = "-1";
if (isset($_SESSION['UserEmail'])) {
$ParamUserEmail_WAATKusers = $_SESSION['UserEmail'];
$query_WAATKusers = sprintf("SELECT * FROM users WHERE UserEmail = %s", $ParamUserEmail_WAATKusers);
$WAATKusers = mysql_query($query_WAATKusers, $login) or die(mysql_error());
$row_WAATKusers = mysql_fetch_assoc($WAATKusers);
$totalRows_WAATKusers = mysql_num_rows($WAATKusers);
it looks like while running the wizard, you selected the email column as the ID column.
the ID column should be the primary key column for the users table, this is a numeric column, not a text column.
to fix the error, double click the WAATKusers recordset. go to advanced view, and edit the ParamUserEmail parameter, change the Type from integer to text.
info425534
Thanks Jason,
You kinda confused me there when you said "change the type from integer to text". But I see that you meant change the type from text to integer. Everything seems to be working now - thanks!
glad to hear it is working.
