Doesn't work
Doesn't work from the time I bought that.
the screen shot is a bit to small to make out the error message, can you compress the screen shot to a zip archive and attach the zip file so the image will not be re-sized.
have you tried deleting the cache file from the users configuration folder?
Yes, I have tried deleting the cache file from the users configuration folder.
Please see attachment.
what is your version of Dreamweaver?
What OS?
Do you get this error when going opening the Create Email Message server behavior for the first time? Or when editing an existing Universal Email instance? or when clicking OK inthe Create Email Message server behavior? Please provide details on the workflow leading up to the error message.
In your Dreamweaver Site definition, do you have a testing server defined? A testing server should be defined.
see the "Defining a Dynamic Site in Dreamweaver" tutorial on the learning resources page.
resources.php?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
I'm using CS5 and Microsoft Windows XP. Get get the error when trying to edit and existing created email. And when I click ok after creating and email behavior.
free-downlo...ebAssistForums
Edit/Delete Message
