Fatal error: Access denied
Thread began 5/06/2011 12:21 pm by A Sound Design | Last modified 5/06/2011 1:39 pm by Jason Byrnes | 4082 views | 3 replies |
A Sound Design
I have configured this for my local PHP testing server and for a remote connection but get the following error:
Warning: mysql_pconnect() [function.mysql-pconnect]: Access denied for user 'root'@'localhost' (using password: NO) in /***/***/***/somedomainname.co.uk/subdomains/sitetesting/httpdocs/Connections/connDB.php on line 25
Fatal error: Access denied for user 'root'@'localhost' (using password: NO) in /***/***/***/somedomainname.co.uk/subdomains/sitetesting/httpdocs/Connections/connDB.php on line 25
Details have been altered for security.
In my connDB.php I have:
# FileName="WADYN_CONN.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_connDB = "localhost";
$database_connDB = "vcb";
$username_connDB = "root";
$password_connDB = "";
@session_start();
$foundConnection = false;
if ($foundConnection == false) {
$domains = explode(",","somedomainname.co.uk/");
for ($domindex = 0; $domindex<sizeof($domains) && !$foundConnection; $domindex++) {
$domainCheck = trim($domains[$domindex]);
if (strpos(strtolower($_SERVER["SERVER_NAME"]),strtolower($domainCheck)) !== false && ($domainCheck == "" || strpos(strtolower($_SERVER["SERVER_NAME"]),strtolower($domainCheck)) == strlen($_SERVER["SERVER_NAME"])-strlen($domainCheck))) {
$database_connDB = "testing";
$username_connDB = "testing";
$password_connDB = "*****";
$foundConnection = true;
$connDB = mysql_pconnect($hostname_connDB, $username_connDB, $password_connDB) or trigger_error(mysql_error(),E_USER_ERROR);
Can someone please see what is up with this. seems to me like it is not recognising the additional connection as it is still trying to connect using the local testing server db name, username and password.
The error is saying that username password combination is not correct.
From the error, it is saying that the root user is not configured with a blank password on your local server.
You will need to enter the correct password for the root user
A Sound Design
I went back and re-entered the details and now it works.
I have to say that this extension is what I have been looking for for a long time. It was so fiddly having 2 separate db connection files, so this works a treat. Thank you so much for developing such a simple extension.
Glad to hear you have it working.
