eCart checkout confirmation problem
Thread begun 5/06/2011 7:02 am by russell298997 | Last modified 5/06/2011 12:55 pm by Jason Byrnes | 1640 views | 1 replies |
russell298997
Can you spot what may be the problem here. I am putting an e-cart to integrate with Paypal Payment Pro. When I try to process a transaction I always go to checkout_failure.asp, th o I believe all the paypal API info is correct.
Assuming that to be the case can you see why it might not work? Also, I thought I had put in the error message string
<%=PP_DirectPayment_Result("Long Error Message")%>
but nothing shows on the page.
Is this because it's for DirectPayment, rather than Paypal Pro? If so I cant see where I can find the code to put the error message in?
I have attached hopefully enough info.
the live pages are at index2.asp
