changing standard design Ribbon + Lightbox
Thread began 5/05/2011 9:43 pm by larry402002 | Last modified 5/17/2011 1:47 pm by Jason Byrnes | 1314 views | 5 replies |
larry402002
I followed the direction in the powergallery custom gallery.pdf to alter the number of images displayed to 5. When I load it onto my site I loose the scroll bars at each end of the ribbon.
What am I doing wrong?
please post a link where i can see the problem to troubleshoot the cause.
larry402002
test page link
Sorry for not getting back earlier.
When insert the code onto a page all the ribbon is displayed, I inserted into the code for 3 images only. You will also notice the scroll bars are missing.
I just followed the information on the WebAssist document called, powergallery_custom_gallery_ht.pdf
testPage.php
here are updated copies of the galleries/global.php file and the webassist/framework/library.php file that should correct the issue.
pg2_4_13_2011.zip
larry402002
still not working
it's still not working,
see gallery.php
I inserted the files as requested. I assume these file go into the powergallery directory?
