Web Assist and CS5.5
Any known issues with the WA extensions in DW CS5.5?
Brad
Brad
CS5.5 will migrate your old extensions which is a nice feature. Note the extensions will not be enabled so you have to turn them back on.
You'll need re-input serial numbers and updates to files such as the three replacement files needed for Framework builder...
No, there aren't any known issues with CS5.5.
I would suggest installing the extensions manually rather than letting the Extension manager import them, I dont trust the extensions manager as far as I can throw it....
