Column bindings
Thread began 5/04/2011 3:01 am by moz1104419172 | Last modified 5/04/2011 7:48 am by Jason Byrnes | 948 views | 1 replies |
moz1104419172
Column bindings
Im working on trying to get my eCart to calculate an addition to the price of one of my items based on how many fields in a certain recordset are empty, this number will multiply the increase in price that comes when increasing the size of the item
I have already put a formula into my cost calculation on the set up for my ecart and have bound the increase in price to my dropdown which selects the size
I have also manually set up a small php script to determine the multiply value which will count how many fields out of 5 are not empty, the number is then stored in a variable, the script is
//Colour counter
$ColourCount = 0;
for ($i=1; $i<=5; $i++) {
if ($row_WADAproducts["ProductFabric".$i."ID"] != "") {
$ColourCount++;
What im having trouble doing (as im no PHP expert) is how can i tell my 'add to cart' button, that the binding for my column [ColourMultiply] is the variable $ColourCount, i tried entering
<?php echo $ColourCount; ?>
into the binding field but that doesnt seem to be working, how can i tell my ecart i want to bind this column to that variable?
Many thanks
that code is correct for binding the column to the ColourCount variable.
if it is not working, I would double check that:
1) the variable is actually getting set the way you expect
2) The code to set the variable is before the add to cart code.
3) The recordset that is used in this script needs to be before the script.
