Error in onchange
Thread began 4/28/2011 5:39 pm by rmruda390861 | Last modified 4/28/2011 11:23 pm by Jason Byrnes | 847 views | 1 replies |
rmruda390861
Error in onchange
Hi. I have V 2.0.3.
I tried to edit an existing menu using the little script icon below the menu..
As the menu writer is loading I get an:
"error in onchange (sel Menu)
Type Erro: wa.addui_values.content.full_path no properties."
After accepting the error message the menu sriter loads and I can see that the "contents:" drop down is "undefined (custom)" Clearly not pointing to me defined menu. When I select the defined menu from the drop down box I get:
"Error generating menu (wa.generate.menu):
TypeError:workinglayout.components has no properties."
And then "undefined" in the Preview Box
Please advise.
Delete the Dreamweaver Cache file from the users configuration folder:
