Plug-in with flash doesn't work in a Template
Thread begun 4/25/2011 11:12 am by kevin389160 | Last modified 5/12/2011 1:39 pm by kevin389160 | 1411 views | 2 replies |
kevin389160
Every time I add a plug-in that has flash in it and make it a template, the flash image stops working. But the plug-in works if I add it to another php page.
What am I doing wrong or does it just not work.
The same thing happens when I add a drop down menu, part of it works but parts of it don't. Like the drop down parts works but the rollover to change the picture on the menu doesn't work.
Can someone please help?
Most likely the issue is related to the path for the swf file.
can you post a link displaying the problem so I can examine the code.
kevin389160
I finally figured out what was happening. I didn't know that you had to save the file based off of a theme in the templates folder. Obviously you must save your templates in the templates folder, but I didn't know that you had to also save the pages that you make off of the themes in the same folder for the links to work correctly.
Is there a way to save your files directly in the main folder and not in the templates folder and have the links work correctly without having to go back and update everything?
