connection to db on godaddy local tester
Thread began 4/22/2011 11:04 am by JBWebWorks | Last modified 4/22/2011 12:15 pm by Jason Byrnes | 886 views | 1 replies |
JBWebWorks
Not sure how to ask the question, but i have a site that is hosted by godaddy and my connection works on their server but does not work on my local testing server.
I use DW CS4 and their code for setting up connection
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_connbrown = "godaddydbserverIP:3306";
$database_connbrown = "mydatabasename";
$username_connbrown = "myusername";
$password_connbrown = "mypassword";
$connbrown = mysql_pconnect($hostname_connbrown, $username_connbrown, $password_connbrown) or trigger_error(mysql_error(),E_USER_ERROR);
I use WA dataassist to set up pages to update,delete,insert tables in the database
work around is setup the site local testing server as the remote server, but don't want to do that.
thanks for your help,
-Jim Balthrop
See the learning resources page for details on setting up a local testing server.
resources.php
when you configure the connection, you need to set it up to use the local MySQL Information.
Before uploading to the remote server, you need to edit the connection to use the remote MySQL connection details provided by go daddy.
