doctype
How do I change the doctype in the store?
Can't seem to find the hidden key;)
Mick
Mick
edit the webassist/themes/<your theme>/templates/index.dwt.php and page.dwt.php files
where <your theme> is the name of the theme your store is using.
Thanks Jason
Thought that might fix the problem - but no go.
On IE8 (virtual XP Pro on a Mac laptop) most of the pages in the store break badly. See here - products_results.php?Search=0
Works fine on Firefox and Safari on PC and Mac.
Any thoughts please?
Mick
when i view source of your page, I see a script before the doctype tag:
<script language="javascript">
if (document.location.protocol != "https:")
document.location.href = "https://www.battleoflakeerie-bicentennial.com" + document.location.pathname;
</script><!DOCTYPE HTML>
Having anything before the doctype tag will cause IE to go into quirks mode, in Quirks mode, IE uses the 5.5 rendering engine.
For IE to function properly, the first line of your page must be the doctype tag, move the script to be after the <head>
