Show user specific search results
Thread began 4/19/2011 12:00 pm by tmcbinc99963 | Last modified 4/20/2011 7:34 am by Jason Byrnes | 1306 views | 3 replies |
tmcbinc99963
Need to have the user be able to select specific records to show up/not show up in search results. One user may wish to keep their phone number private, another an email address. Is this possible in DataAssist? If not, how is this done? I've look all over the web for Mysql options with no luck.
to be able to accomplish this will very specific planning when creating the users table and some hand coding.
you will need to determine ahead of time which columns to allow the user to mark as private.
for each column that will be c=private, you will need another column that will be used to mark it.
for example, lets use the PhoneNumber column, you would need to add PhonePrivate column. If it is to be private, set the value of that column to 1, 0 for public.
the on the results page, add an if statement to check if the PhonePrivate column equals 1:
<?php if($row_RecordsetName['PhonePrivate'] != 1) echo($row_RecordsetName['PhoneNumber']); ?>
tmcbinc99963
Thanks, I'll give it a try.
you're welcome.
