Progress bar for UE without form on page?
Is there any way to have a progress bar on a page that uses the 'before page load' method of spitting out emails?
EDIT - I.E. when there is no 'form' on the page?
The progress bar can only be applied to a form.
The work around would be to get the page working using a form submit with the progress bar, then add a javascript function to the page onload event to submit the form:
<body onLoad="document.form1.submit()">
This way the progress bar has the form submit it needs to work, but the page appears to trigger on page load.
Edit/Delete Message
