Repeat Region
Thread began 4/04/2011 2:57 pm by CUAD | Last modified 4/05/2011 11:30 am by Jason Byrnes | 1631 views | 3 replies |
CUAD
Repeat Region
I currently have a repeating region with the html editor. Everything on my regular form elements shows up fine but in the editor it one shows the first record in all of the editors. It will not repeat and show the next item that is in the database. Any idea why this is happening. Can the html editor be used in a repeating region?
Notice the titles on the images. They are different columns in the database. Also notice how the editor does not change. I am using the same recordset to display the text.
The text area box under the word blurb shows the text that should be in the HTML editor. Any insight would be greatly appreciated.
HTML Editor will not work in repeat regions, this is a bug that will be addressed in the next update.
CUAD
Is there any clue to when you plan on releasing the next update?
I dont have a time frame for when it will be released at this time.
