Required file Validation problem
Thread began 4/04/2011 7:47 am by phebberd116714 | Last modified 4/05/2011 6:54 am by Jason Byrnes | 1581 views | 3 replies |
phebberd116714
I have a form that requires a pdf file to be uploaded.
I validate by type (pdf) correctly but when I try to add a required validation, the file is not being recognized. I think I must have made an error in how I am applying the validation.
Here is the server validation:
if (isset($_POST["Insert_x"])) {
$WAFV_Redirect = "pdfFiles_Insert.php?invalid=true";
$_SESSION['WAVT_pdfFilesInsert_376_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateFE(((isset($_FILES["pdfUpload"]))?$_FILES["pdfUpload"]["name"]:"") . "",".pdf",false,1);
$WAFV_Errors .= WAValidateRQ(((isset($_FILES["pdfUpload"]))?$_FILES["pdfUpload"]["name"]:"") . "",".pdf",false,2);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"pdfFilesInsert_376");
Here is the file field with the validation errors:
<input type="file" name="pdfFile" id="pdfFile" />
if (ValidatedField('pdfFilesInsert_376','pdfFilesInsert_376')) {
if ((strpos((",".ValidatedField("pdfFilesInsert_376","pdfFilesInsert_376").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<br />
<span class="errorRed"><img src="images/icon-error.gif" alt="" width="16" height="14" align="baseline" />&nbsp;You can only upload PDF files.</span>
<?php //WAFV_Conditional pdfFiles_Insert.php pdfFilesInsert_376(1:)
if ((strpos((",".ValidatedField("pdfFilesInsert_376","pdfFilesInsert_376").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
<br />
<span class="errorRed"><img src="images/icon-error.gif" alt="" width="16" height="14" align="baseline" />&nbsp;Please select a PDF file.</span>
<?php //WAFV_Conditional pdfFiles_Insert.php pdfFilesInsert_376(2:)
Can anyone point out what I am doing wrong.
Thanks in advance.
this line:
should be:
$WAFV_Errors .= WAValidateRQ(((isset($_FILES["pdfUpload"]))?$_FILES["pdfUpload"]["name"]:"") . "",false,2);
one thing confuses me in your post though; in the validation code, you are validating a file field named pdfUpload, but the file field on your page:
is named pdfFile
phebberd116714
Thank you Jason,
Your changed worked perfectly.
Yes, I had made an error, the validation should have been on the field pdfFile. That's what happens when you copy code from another page and don't take care&#8230; Duh I need a brain transplant!
No worries, glad to hear it is working.
