Fatal error: Cannot redeclare wa_ab_getloopedfieldname()
Thread began 3/30/2011 12:26 pm by Daryl | Last modified 5/09/2011 3:57 pm by neo314 | 1719 views | 3 replies |
DarylBeta Tester
Fatal error: Cannot redeclare wa_ab_getloopedfieldname() (previously declared in /home/sites/xxxx.co.uk/public_html/WA_DataAssist/WA_AppBuilder_PHP.php:11) in /home/sites/xxxx.co.uk/public_html/webassist/database_management/wa_appbuilder_php.php on line 19
This is on a Data Assist Page with two select lists populated from a database and universal email applied to a submit button associated with each list.
DarylBeta Tester
I found the answer that you had given me before....
showthread.php?t=19580&highlight=Fatal+error%3A+redeclare
Why would this file have been recreated?
Just so that I can be aware so that I know to make this change again in the future...
that file will get recreated any time you use Universal Email. if you edit an existing Universal Email behavior or create a new one, it will recreate that file.
neo314
I just encountered the same problem from a different cause. I posted a response in the thread mentioned above. I think implementing that fix in the extension would prevent the problem from reoccurring on sites that have old and new WA file structure in them.
http://www.webassist.com/forums/showthread.php?t=19580&highlight=Fatal+error%3A+redeclare
