HTML Editor 3 & Framework Builder
I just upgraded to HTML Editor 3 and did some preliminary tests. I am having a problem with the KFM (File Manager) launching properly when the page is loaded with Framework Builder.
EG: I have an index.php folder in root, that loads pages (via framework builder) from my plugin folder. When I load a page that includes "html editor" the editor itself loads no problem, but when I launch the file manager (from an image/link/flash icon in the editor) it throws a 404 error. I have to edit the filemanager config setting to make it work properly. (Note: I do not edit the KFM configuration file, I edit the reference to the KFM in the editor instance "$CKEditor_config["filebrowserBrowseUrl"] ="). I have to remove a "../" from the referenced link.
Although it is easy, and I don't mind doing this by hand, I think it is really important that your tools work with one another - seamlessly. They need to know when they are being pulled in with "Framework Builder" and compensate for that.
This problem did not occur with HTML Editor 2 (btw - I liked that KFM file manager more, but maybe I'll get used to this newer one), and I have also tried with and without setting a baseURL meta tag.
