Powergallery Licensing
Thread began 3/30/2011 6:51 am by CraigR | Last modified 3/30/2011 10:05 am by Jason Byrnes | 163 views | 3 replies |
CraigRBeta Tester
I purchased powergallery 1.1.0, at the point before the licensing restriction was placed upon it.
I notice we are now on 1.2.x
I am wondering what the deal is as far as dot releases.
If I install 1.1.0, I can use this freely, as there is no requirement for a s/n on installation, and I purchased it before the limitation was implemented.
If I install the latest version, a s/n is required.
if the latest dot release is for bug fixes, shouldn't I be entitled to install this version freely?
Alternatively, is it possible/permitted to do the ftp update of 1.2.x on a 1.1.0 installation ?
you are entitled to the license that you purchased.
You purchased the product when the unlimited domain license was in place, we cannot change the license that you purchased after the fact.
Since you purchased before the license change took effect, you can install power gallery 1.x, including all of the current fixes on unlimited domains.
CraigRBeta Tester
thanks Jason.
I assume this means that for any version of 1.x , the serial number I have been allocated will validate on all future installations, without me jumping through hoops.
yes that is correct.
