Form Toolkit conflict with FMStudio Pro
Thread began 3/28/2011 4:20 pm by bcheang | Last modified 3/30/2011 6:24 pm by bcheang | 2658 views | 5 replies |
bcheang
Does anyone use Form Toolkit with FMStudio Pro? FMStudio Pro is a Dreamweaver extension that facilitates creation of webpages with Filemaker Pro server. It also creates PHP pages, but Form Toolkit refuses to work saying that I must use PHP.
If you disable the FMStudio Pro extension in the extensions manager, does it fix the problem?
bcheang
When I create a document by choosing plain PHP, there is no problem. However, I need to use PHP for FMStudio Pro. If I choose this option, Form Toolkit doesn't allow me to add any of its objects.
A screen snapshot is attached.
ScreenSnapz.pdf
mpetrov
As the lead developer of FMStudio Pro, I would like to address the confusion:
- FMStudio Pro is an advanced extension that introduces a new PHP Server Model, therefore it will not cooperate well with many other PHP extensions. This had to be done as it is not an SQL based database connection.
- Form Toolkit will work just fine next to FMStudio, just not inside of FMStudio pages
My Recommendation:
- Start with a plain PHP page, use Form Toolkit to do what you need
- Then by hand integrate the generate Form Toolkit code into your FMStudio Pro pages
The code will not be editable in Dreamweaver using the Form Toolkit tools, but it should work just fine - after all both extensions produce proper code that works in PHP. The integration of the code by hand into FMStudio pages should be easy enough to do.
Thank you very much for the clarification mpetrov.
bcheang
Thank you mpetrov. In a way, it is strange that I should hear from you here. I don't seem to get replies when posting on fmwebschool forums for FMStudio...
If you read this, when will complete documentation for FMStudio Pro be complete?
