Check out wizard not functioning
Im getting an error when I click on the Checkout Wizard on eCart 4 -- it says "While executing onLoad in WA eCart CheckoutWizard.htm, a JavaSript error occured"
Any suggestions?
Any suggestions?
Delete the Dreamweaver Cache file from the users configuration folder:
Uninstalling the cache file didn't work. The next step is to uninstall ALL my extensions??
I would try uninstalling ecart, then installing it again, what version of Dreamweaver are you experiencing this in?
I tried uninstalling eCart and reinstalling - same error - Dreamweaver CS3
What is the build number of the Dreamweaver version?
Go to Help -> About Dreamweaver. click the about screen once to scroll to the end, the build number should be listed there.
I downloaded a trial for CS5 and installed the extension and got it to work. Im not at all familiar with 5 but I uploaded the file but Im missing something.
cicsaweb.php
cart.php
please send a copy of the WA_eCart/eCart1_PHP.php file so i can investigate the cause of the error.
eCart1_PHP.php
Im getting an invalid file type when I try to send this to you
If you want to email me, I can email you back the file and user id/password for the server if you need it. It will be tomorrow as I have to leave now.
