Powerstore 4.01 update to 4.5 admin error
Thread began 3/27/2011 7:07 pm by info385819 | Last modified 3/28/2011 10:04 am by Jason Byrnes | 1210 views | 3 replies |
info385819
Hello,
We updated the powerstore per the instructions provided. The admin/settings area
now offers the updated choice changes for currency but, when selected the store does not change currency?
Also,
The following has not changed:
1) Shipping settings have not updated ( meaning the new updated choices are not available under settings )
2) admin Taxes have not updated ( meaning the new updated choices are not available under settings )
** Recieved this error when trying to update Mysql db.
Error
SQL query:
ALTERTABLE ps4_products ADD ProductNonTaxable int( 1) ;
MySQL said:
#1060 - Duplicate column name 'ProductNonTaxable'
Why would this occur?
try running this script on your Database to correct the problem
settings_synch.sql.zip
info385819
RE: PS 4.0.01 upgrade too PS4.5 Admin Error
I insured that the folder install/webassist and all files contained in the folder were copied. Admin still does not show any additional updates? also, the .sql file ( settings_synch.sql ) was used from another post to correct an error for existing nontaxtable and this update went through correctly to the db.
But, The store still does not show the updates , nor will the update that does show for ( currency ) change the store.
