parse error on line 62
Hello,
Just inserted a simple form at:
contact1.php
But I receive an error message. Not sure what it means. Any ideas?
Hello,
contact1.php
It means there is a syntax error at line 62.
Please send a copy of the page so i can see the code to determine what the cause of the error is.
Hi Jason,
Here's a copy of the page.
Sorry - had to delete previous attachments. Assumed this would have been automatic.
the problem is caused by the validation show if behavior.
Open the server behaviors list, and double click each of the validation show if behavior to reset them.
Hello,
I'm seeing another error message now?
contact1.php
Any idea what would be causing this?
change line 114:
if ((isset(["SimpleContact_submit"]))) {
if ((isset($_POST["SimpleContact_submit"]))) {
Thank you Sir. That seems to have fixed it. It gets sent to my spam folder but I can live with that for now.
Any idea why these errors occured? I simply added info to the wizard and clicked 'Finish'.
Thanks again.
These are not problems I have encountered or can reproduce, so I do not know what the cause is.
