Map icons will not display and not available
Thread began 3/25/2011 2:57 pm by marketing331920 | Last modified 3/28/2011 8:59 am by asnw0764437428 | 1111 views | 1 replies |
marketing331920
I cannot get the map icons to display using gps coordinates. This error occurs " While executing onClick in wagmp_map.htm, the following JavaScript error(s) occured: " At line 450 of file " C:|program files (x86)\Adobe\Adobe dreamweaver CS4\configuration\commands\wagmp_map.js:wa.markerStyles[style]has no properties"
Help? What does this mean?
(I do not know is this makes a difference either...but this message keeps popping up in CS4 DW " The following JavaScript error(s) occured: Unable to open script file "C:|Program Fiels(x86)\Adobe|Adobe Dreamweaver. CS4\Configuration\Shared\Webassist\FormBuilder\Library\WA_database.js" error 3
asnw0764437428
Try quiting Dreamweaver and delete the cache file located at (Win XP);
C:\Documents and Settings\Andy\Application Data\Adobe\Dreamweaver CS4\en_US\Configuration\WinFileCache-XXXXXXX.dat
If that doesn't work uninstall the FormBuilder extension and re-install again and answer yes to all in the prompts during installation.
