Satellite view on by default
I would like to add satellite views of various landmarks, is it possible to have the satellite view option turned on automatically when the maps are displayed?
Thanks in advance
Thanks in advance
This is not an option in the UI so you would have to look up how to do it with the Google Maps API and work that code back into your map. Should be possible if you know the basics of client side javascript.
