Help!!! Still having problem with db install with PS4.5
Thread began 3/23/2011 3:52 pm by vonniea383657 | Last modified 3/23/2011 3:57 pm by Jason Byrnes | 681 views | 1 replies |
vonniea383657
Hi Jason
From yesterday..
I am trying to use the installation wizard to set up PS4.5. When I type in the data base information, I get the error:
ERROR: Database could not be created.
Out of range value for column 'RateWeight' at row 1
What does this mean and how can I fix it?
I am using an Apache/MySql localhost set up.
Thanks,
~Vonnie
Your reply:
in the install/scripts/db.sql (or upgrade sql you are using), update the line that reads:
Code:
INSERT INTO `ps4_shippingrates` VALUES ('1', '1', '1000000000.00', '0.00');
Code:
INSERT INTO `ps4_shippingrates` VALUES ('1', '1', '1000000.00', '0.00');
So I did and I now have the error:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'CREATE TABLE IF NOT EXISTS `ps4_categories` ( `CategoryID` int(11) NOT NUL' at line 1
Waht now?
I have been struggling with this install for 2 days now!!
~Giovonnae
You have this reported in another thread as well, see my reply to the other thread;
