File manager in multiple insert issue
Thread began 3/23/2011 2:43 pm by ijs174940 | Last modified 3/24/2011 11:22 am by Jason Byrnes | 734 views | 2 replies |
ijs174940Beta Tester
Hi All
I have built a standard form and applied the multiple update and all items in the form are inserted into the db correctly from the multiple entries but with one exception. One of the fields is a first file manager field, the first instance of this works correctly but the second one onwards does not? even before submitting when I select the second instance select the image the field stays blank with no image path inserted?
I have checked the field has been updated with the auto number feature which it has. Am I missing something?
Think I found the issue which requires a little hand coding to fix
This is before
<div style="float:left;">
<img src="../webassist/kfm/themes/webassist_v2/spacer.gif" id="htmleditor_image_1" align="top" />
</div>
<img src="../webassist/kfm/themes/webassist_v2/icon_folder.png" width="20" height="18" id="htmleditor_browse_1" name="{dds:'../', startup_folder:'', show_sidebar:true, width:600, height:400}" style="vertical-align:bottom; padding-bottom:2px; visibility: hidden;" />
This is after
<img src="../webassist/kfm/themes/webassist_v2/spacer.gif" id="htmleditor_image_<?php echo $RepeatSelectionCounter_1; ?>" align="top" />
</div>
<img src="../webassist/kfm/themes/webassist_v2/icon_folder.png" width="20" height="18" id="htmleditor_browse_<?php echo $RepeatSelectionCounter_1; ?>" name="{dds:'../', startup_folder:'', show_sidebar:true, width:600, height:400}" style="vertical-align:bottom; padding-bottom:2px; visibility: hidden;" />
It appears that when you use the insert or update multiple option it only appends the name of the main input field it misses out the two other img id which also need to be appended,
May be a fix for the next release?
Thank you for reporting this, I have logged the issue in our bugbase to be investigated for a future update to HTML editor
