Persistent alert message after removing CSS Sculptor extension
Thread began 3/23/2011 9:54 am by kent349598 | Last modified 3/23/2011 11:30 am by Jason Byrnes | 2009 views | 3 replies |
kent349598
After removing the CSS Sculptor extension with the Extension Manager, launching Dreamweaver CS4 (iMac i5, OS 10.6.6) prompts an alert message stating 'Unable to find file WA_Memento.htm in the Configuration/Floaters directory. The floater will not be shown.'
The alert interrupts the launch process until the message is dismissed, resuming the launch process.
What else can I do to eliminate this message?
TIA,
kent349598
Go to Window -> Workspace layout -> Reset '<Your Layout Name>'
where <Your Layout Name> is the name of the Dreamweaver layout you are using for your workspace.
kent349598
That worked - thanks!
you're welcome.
