Polls and Surveys
Hello!
I would like to know if WebAssist has any solution for creating Polls or Surveys?
I have looked around and found nothing.
So I submit to you all.
Any suggestions are well apreciated as always.
Thank you very much.
Hello!
A poll or survey is really just a form that gets stored in a database.
you can create the form using Dreamweaver, or CSS Form Builder. then Use DataAssist to store the submitted form into the database.
If you wanted to chart the survey results, you could use Dynamic Web Charts.
You are right that it is an insert, but infact is a multiple insert, since every question has it's own id and it stores the answers in a table called answers.
Any idea of how to achieve multiple insert with mysqli? My form is static and I just use a unique id to each question in order to individualise it when I save the answer. My issue is how to run a multiple insert.
Multiple insert would take hand coding to accomplish. we could help you set this up through a premiere support appointment:
http://www.webassist.com/premier_request.php
