Admin Levels
Are there admin levels with Powerstore? Like superadmin -adjust design and such,
and just an admin for adding products and such?
yes, the super admin user is the user you configure during the install.
once logged into the admin panel, go to users -> add users to add new users, if you set the user level to administrator, they will be able to access the admin panel and add new products, and manage content.
Ok one more question. I am trying to get a proposal together.
If I give the client "Admin" rights I suppose there are tabs missing from the store manager.
To save you time here is my guess (just let me know if I am right).
Admin Does Not get to see:
Design Tab
Settings Tab
Content Tab/Area works the same as PowerCMS 2 = admin and superadmin have different rights
They Can see:
Dashboard Tab
All things in Products Tab
All things in Users Tab
All things in Orders Tab
I also wonder about the content of the Help System. If they can see everything in the help system? If so no big deal I can modify that, but it would be nice if their access was limited.
Yes, that is all correct.
the help system is intended for you to modify for your client.
see the "Modifying this help system" section of the help.
