Custom Column and Calculation
Thread began 3/21/2011 6:03 am by brianw101189 | Last modified 3/21/2011 10:51 am by Jason Byrnes | 1237 views | 3 replies |
brianw101189
I've setup a new column called CompPrice, which is set to store a secondary pricing. I'm now looking to add the totals of the CompPrice column, to give a secondary GrandTotal in the cart.
I have added a new calculation called TotalCompPrice, which multiplys the Quantity and the CompPrice. Now I'm looking to figure out how to add the TotalCompPrice for each item and have a secondary GrandTotal.
I've added another calculation called CompGrand, and added the calculation [TotalCompPrice] but that doesn't seem to be working.
Any help or suggestions would be greatly appreciated.
to display the line item total, use;
<?php echo WA_eCart_DisplayMoney($<YourCartName>, $<YourCartName>->DisplayInfo("TotalCompPrice")); ?>
to display the grand total, use:
<?php echo WA_eCart_DisplayMoney($<YourCartName>, $<YourCartName>->TotalColumn("TotalCompPrice")); ?>
where <YourCartName> is the name of your eCart object.
brianw101189
Thank you, works perfect.
you're welcome.
