DD with DataAssist
Thread began 3/19/2011 6:53 pm by virtualbr | Last modified 3/21/2011 10:45 am by Jason Byrnes | 1646 views | 1 replies |
virtualbr
DD with DataAssist
Hello!
I have created the admin of my pages with DataAssist.
Where I have corretly selected both tables for the menu options as parent and child (although in my system they have diferent names, the principle is the same).
I open the insert page, where my form has been generated, and select the "Create Dynamic Array" option on my Server Behavior Panel.
No error message, but nothing new shows up on my behavior panel.
So i proceed to the Behaviors Panel and the option "populate list from array" is greyed out.
Since the only thing diferent in my form is that it was generated with Data Assist, and I was unable to find instructions for this specific combination, I submit to you.
Anyone ever experienced this?
Any help apreciated.
Thank you.
the create dynamic array behavior will only be available if the following conditions are met:
1) You must have at least 2 select lists on the page (One to be parent and one to be child)
2) you must have a Create dynamic Array server behavior on the page.
if you have further problems, send a copy of your page so I can see the code.
