Wildcard in where
Thread began 3/17/2011 2:14 pm by tom.kurshinsky298027 | Last modified 3/17/2011 6:46 pm by Jason Byrnes | 1420 views | 9 replies |
Wildcard in where
I have a drop down box that I use as the selection for the where clause in a query, works fine. Now I want to add a wildcard character to get all records. If I use a % character I get a 406 not acceptable error message. I've tried using all manner of quotes around it but get the same. Any ideas?
just use an empty option:
<option value="">Show All</option>
in your select list.
Returns no records.
Further info. The dropdown gets populated from a query. And I'm adding the All Records manually.
<form action="Tdrill_ResultsDynamic.php" method="get" enctype="multipart/form-data" name="TSelect" id="form1">
<div align="center">
<select name="TechSel" size="1" id="TechSel">
do {
<option value="<?php echo $row_initial['techid']?>"><?php echo $row_initial['Technology']?></option>
} while ($row_initial = mysql_fetch_assoc($initial));
$rows = mysql_num_rows($initial);
if($rows > 0) {
mysql_data_seek($initial, 0);
$row_initial = mysql_fetch_assoc($initial);
</select>
<input type="submit" name="TechButton" id="TechButton" value="Submit" />
</div>
</form>
can you send your entire results page so i can see the whole code in context.
Attached a text file.
results.txt
in data assist search, you have the techid column set to filter on the S_techid text box.
$WADbSearch1->addComparisonFromEdit("techid","S_techid","AND","Includes",0);
instead of hard coding the where cluse to use your select list, why not just delete the S_techid text box, and rename the select list to S_techid?
data assist search will dynamicly create the where clause using form elements that pass a value.
meaning that if your select list default empty option is selected:
that cxolumn will not be included in the where clause.
the way you are doing it now would require hand coding the recordset with an if statement to only include that column in the where clause if a value is passed.
  $WADbSearch1->addComparisonFromEdit("techid","S_techid","AND","Includes",0);.
So in DataAssist Search, I delete that line? And on my start page I rename the dropdown to S_techid?
no, leave that line in place.
in the recordset, delete the where clause you have added.
in your search form, delete the S_techid text field.
then rename the TechSel select list you created to S_techid
Sorry. I'm feeling dense.
"in the recordset, delete the where clause you have added."
and the variable?
"in your search form, delete the S_techid text field."
Do you mean the seperate search page in this case drill_search.php? Because there is no S_Techid text field there because I deleted it while editing that page.
yes, and the variable,
if you have already deleted that field, then dont worry about it, just name the select list S_techid.
