insert the map
Hello,
When insert the pro map, i click at the right side of a
input box but the map cover the input box.
How to insert the pro map to the right side of the form ?
Thanks.
Hello,
Thanks.
you would need to do this in your layout.
either using a table or using CSS and Divs
Create one container for the for and a separate container for the map.
