No Download
Thread began 3/16/2011 11:56 pm by Screamin'Dean | Last modified 3/18/2011 7:01 am by Jason Byrnes | 1937 views | 4 replies |
Screamin'Dean
No Download
Hi - I'm having trouble getting the download behaviour to work as it should.
Here's the code …
<?php require_once("../WA_DigitalFilePro/HelperPHP.php"); ?>
//initialize the session
if (!isset($_SESSION)) {
session_start();
// ** Logout the current user. **
$logoutAction = $_SERVER['PHP_SELF']."?doLogout=true";
if ((isset($_SERVER['QUERY_STRING'])) && ($_SERVER['QUERY_STRING'] != "")){
$logoutAction .="&". htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_GET['doLogout'])) &&($_GET['doLogout']=="true")){
//to fully log out a visitor we need to clear the session varialbles
$_SESSION['MM_Username'] = NULL;
$_SESSION['MM_UserGroup'] = NULL;
$_SESSION['PrevUrl'] = NULL;
unset($_SESSION['MM_Username']);
unset($_SESSION['MM_UserGroup']);
unset($_SESSION['PrevUrl']);
$logoutGoTo = "http://www.mysite.com";
if ($logoutGoTo) {
header("Location: $logoutGoTo");
exit;
session_start();
$MM_authorizedUsers = "clientnamehere";
$MM_donotCheckaccess = "false";
// *** Restrict Access To Page: Grant or deny access to this page
function isAuthorized($strUsers, $strGroups, $UserName, $UserGroup) {
// For security, start by assuming the visitor is NOT authorized.
$isValid = False;
// When a visitor has logged into this site, the Session variable MM_Username set equal to their username.
// Therefore, we know that a user is NOT logged in if that Session variable is blank.
if (!empty($UserName)) {
// Besides being logged in, you may restrict access to only certain users based on an ID established when they login.
// Parse the strings into arrays.
$arrUsers = Explode(",", $strUsers);
$arrGroups = Explode(",", $strGroups);
if (in_array($UserName, $arrUsers)) {
$isValid = true;
// Or, you may restrict access to only certain users based on their username.
if (in_array($UserGroup, $arrGroups)) {
$isValid = true;
if (($strUsers == "") && false) {
$isValid = true;
return $isValid;
$MM_restrictGoTo = "restrictaccess.php";
if (!((isset($_SESSION['MM_Username'])) && (isAuthorized("",$MM_authorizedUsers, $_SESSION['MM_Username'], $_SESSION['MM_UserGroup'])))) {
$MM_qsChar = "?";
$MM_referrer = $_SERVER['PHP_SELF'];
if (strpos($MM_restrictGoTo, "?")) $MM_qsChar = "&";
if (isset($QUERY_STRING) && strlen($QUERY_STRING) > 0)
$MM_referrer .= "?" . $QUERY_STRING;
$MM_restrictGoTo = $MM_restrictGoTo. $MM_qsChar . "accesscheck=" . urlencode($MM_referrer);
header("Location: ". $MM_restrictGoTo);
exit;
WA_DFP_SetupDownloadStatusStruct("WA_DownloadResult1");
if(isset($_POST["dload_1"])){
WA_DFP_DownloadFile("WA_DownloadResult1", "../client_files/client_name/", "logo.eps", "logo.eps", false, false, false, "", "", "", "");
If you could throw some light on this, that would be grand.
Thanks!
please compress the page into a zip archive and attach the zip file to your reply so i can see the code in context.
Screamin'Dean
This post has been deleted.
the problem is the method attribute in your form elements
<form action="" method="submit" name="form1" id="form1">
submit is not a valid method. there are 2 options for the method attribute:
POST
GET
you need to use POST:
<form action="" method="POST" name="form1" id="form1">
Screamin'Dean
Thanks, Jason.
you're welcome.
