Changing the way inCart works ..
Thread began 3/16/2011 7:32 am by josephman1988419833 | Last modified 3/16/2011 4:04 pm by Jason Byrnes | 712 views | 1 replies |
josephman1988419833
Hi guys,
Can I use the inCart function on another filed?
I've set up a LineCode property so we can check to see if a product with a LineCode is in the cart, rather then the ID.
Hope someone can help.
Regards,
Joe.
no, the inCart function can only use the ID column. Are you trying to create a discount, shipping or tax rule?
if so, you can use the items with a specific value trigger option of calculation option.
Or are you trying to show a message on the page if an item with a specific LineCode value is present?
if that's the case, then use this code:
<?php if($<Your eCart Object Name>->ConditionalTotal("Quantity""LineCode""Line Code Value") > 0)) { ?>
Your Message
<?php ?>
you will need to substitute:
for the name of your eCart object, and also:
Line Code Value
for the actual value you are looking for.
