Upgrade 3 to 4.5
Is the process to upgrade from PS3 to PS4.5 the same as described in PS3 to PS4?
Mick
Mick
No, it's a bit different.
First off, i would suggest making a back up of the site and the power store database.
then delete all of the power store files and folder, except for the connection folder.
Next copy all of the php files and folders from the power store zip file you downloaded into your poser store site.
Next copy the install/webassist folder form the power store download into the root of the power store site.
then run the install/scripts/v3_v4_update_script.sql file on the database
Thank you
Where do I find…
Mick
in the power store download zip file, there is a folder named install, inside the install folder is a folder named scripts this folder contains the v3_v4_update_script.sql file.
