Theme Cutomization Errors
Thread began 3/15/2011 1:59 pm by mick358555 | Last modified 3/17/2011 7:37 pm by Dani Chankhour | 1508 views | 7 replies |
mick358555Beta Tester
When Customising a theme by changing the logo graphic an empty widow opens with error as shown below. Seems this happens no matter which theme is loaded.
My system is Windows Vista Business SP2
Processor E45oo @2.20Ghz
3Gb RAM
32 bit Operating system
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; Trident/4.0; Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1) ; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; .NET4.0C; InfoPath.3)
Timestamp: Tue, 15 Mar 2011 20:54:43 UTC
Message: 'jQuery' is undefined
Line: 5
Char: 1
Code: 0
URI: can-minify
Message: 'kfm' is null or not an object
Line: 2
Char: 1
Code: 0
URI: en.js
Message: 'kdnd_targets' is null or not an object
Line: 378
Char: 65
Code: 0
URI: can-minify
Message: 'HooksDirectoryReadonly' is null or not an object
Line: 313
Char: 53
Code: 0
URI: can-minify
Message: Object expected
Line: 251
Char: 7
Code: 0
URI: ?theme=webassist_v2&startup_folder=logos&showsidebar=false
Anna Robinson
Thanks for reporting. Someone from our QA team will respond if they need any help reproducing. Otherwise, you can expect a fix soon. We are still pushing fixes live daily.
elevy388997Beta Tester
I just clicked on the design tab in the admin area and then tried to go back to the main page and got this error:
Warning: require_once(webassist/themes/theme_open.php) [function.require-once]: failed to open stream: No such file or directory in /home/cafecommerce/mycafecommerce.com/page.php on line 2
Fatal error: require_once() [function.require]: Failed opening required 'webassist/themes/theme_open.php' (include_path='.:/usr/local/php5/lib/php:/usr/local/lib/php') in /home/cafecommerce/mycafecommerce.com/page.php on line 2
But after 2 minutes of waiting, i refreshed and all seems well. I tried to replicate the problem by clicking on random tabs, and couldn't do it again.
Dani Chankhour
Can you please tell me what browser you were using when you came across the issue?
and if possible the version of the Browser?
Thanks.
Firefox 3.6.15
Dani Chankhour
The reason for the errors you were getting is a result of the files being changed on the server which is why you were not able to reproduce the issue.
Please let me know if you see these errors again.
Thanks.
Originally Said By: Dani Chankhour
Thanks.
Hi Dan
If the question was also for my input then I tested with IE8 and Google Chrome 10.0.648.151
Having checked I can now open as expected such that I can go on to customize. However couple of issues:
1. on saving the new template the thumbnail created to display the new style does not reflect the changes.
2. When recalling the newly created template it does however open looking as intended but does open with errors:
Timestamp: Fri, 18 Mar 2011 00:47:37 UTC
Message: Syntax error
Line: 1
Char: 1
Code: 0
URI: en-gb.js?t=ABLC4TW
Message: 'lang.contextmenu.options' is null or not an object
Line: 47
Char: 1845
Code: 0
URI: ckeditor.js?t=ABLC4TW
Message: 'console' is undefined
Line: 373
Char: 5
Code: 0
URI: styler.js
Also it informs you that you appear to still be customizing a theme, however after cancelling and reopening I could no longer repeat this error message althouth the 'with errors' message still exists.
Mick Lock
Dani Chankhour
Thanks mick358555,
1 - this is a known issue for the time being
2 - it seems there are some debugging statements that are left behind that are causing these issues, i will look into the issue further and post back once it is fixed.
Thanks.
